Failed to bind to a socket.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
Socket bind failed. Sockets error code = %p1% Socket ID = %p2% Socket type = %p3% Socket family = %p4% Socket protocol = %p5% Stub socket handle = %p6% Application handle = %p7% Local inet address = %p8% Local port = %p9%
| Name | Type |
| p1 | sInt |
| p2 | sInt |
| p3 | xInt32 |
| p4 | xInt32 |
| p5 | xInt32 |
| p6 | uInt32 |
| p7 | uInt32 |
| p8 | VarFmtByteArray |
| p9 | uInt16 |
